Can't connect to SRS
tymatk
Post by tymatk »
Hi
Can't connect to SRS, is there any other setting for me to be able to do this?
Connect and read ECU, everything else is fine.
Re: Can't connect to SRS
Try adjusting the "Ini timer Offset" value under Settings->Communication. Try positive and negative values.
tymatk
Post by tymatk »
Thank you, will give it a shot.
tymatk
Post by tymatk »
Set to -1, fixed it.
